i just converted my 53 sc to 12v with no change to tin work. i used bob m's wiring diagram found on the web. used an delco alt and made my own brackets out of 3/16s steal. installed a warning light. I have extra one if you need one ill make you a bracket like i made and will send you one if you want to go that route
you have to user a 12v coil and i had to modify the brackett a little fot it to fit and change your 1133 light bulbs to 1143 light bulbs if your using the teardrop loghts
and be sure to attach your ground wire to a starter bolt. i found out the hard way
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
