Re: Hydraulic pump optios
Posted by Jim on January 10, 2001 at 07:57:59 from (199.240.128.68):
In Reply to: Hydraulic pump optios posted by dave on January 09, 2001 at 21:20:05:
You need to take a pressure reading at the outlets of your 544. Then take a reading at the pump( turn the front wheels to get the pressure ). One plug is for the main pump and the other is for the 3pt. If both readings are the same the steering flow control valve is OK If they are different the valve is bad.
Post your pressures when you get them.
Post A Followup
: Re: Re: Hydraulic pump optios
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
