Re: Belly Pump Oil Change
Posted by mkirsch on January 02, 2015 at 11:45:44 from (72.45.143.81):
In Reply to: Belly Pump Oil Change posted by Old Man Grizz on January 02, 2015 at 10:27:56:
There's no trick to it. Remove the drain plug on the bottom, and you should get 6 quarts of oil out.
Have you poked a stiff wire up in there to see if a wad of sludge has covered over the hole? Have you tried to push some compressed air into the filler hole?
