Re: SMTA Wiring
Posted by Phil Auten (TX) on January 10, 2001 at 09:44:37 from (64.217.53.44):
In Reply to: SMTA Wiring posted by Randy S. on January 10, 2001 at 09:07:58:
Randy,
If your tractor is still using a generator look in Research & Info on the left side of the screen. Then find Article Archives in that section and click on it. There are two types of generators used on tractors. You would most likely have a Third Brush type so click on the Third Brush Generators article. There's a schematic at the bottom of the article.
If it turns out you have a two brush generator, use the Two-Brush Generators article instead.
If you have an alternator, find out if it's internally regulated or not. You may not need a regulator at all. If you do need a regulator, I would consider replacing the alternator with a GM 10Si alternator that is internally regulated. It will work forever without any maintenance or problems. In that case, use the article A Step-by-step 12-Volt Conversion by Bob M. It's excellent and there's a schematic at the bottom of it too.
My 2¢,
Phil
Post A Followup
: Re: Re: SMTA Wiring
Today's Featured Article - Ford Super Dexta - by Anthony West. The rusty blue tractor caught my eye as my truck zipped by the farm implement business. It looked so fornlorn amongst the lineup of newer equipment. But it was just the right size for my small farm. I stopped in and asked the proprietor for further information. "It's a 64 Ford Super Dexta", he said. "It's a tough little tractor, although it's a hard starter being a diesel and all." He did manage to get it running, compliments of a can of ether. Once started it putted along pretty good. It ... [Read Article]
