take the 4 bolts and e clips ou t of the cast. Clamp the topshaft in the vise so the carrier is upside down. Replace the spring steel spacer over the bearing. Put the ramp and sprang over the carrier while twisting the sprag slightly counter clockwise. Tap with a hammer until seated over the bearing. Place the cast iron spacer. Slide the back gear and cast assembly back into the carrier. Take out of the vise and reinstall the 4 bolts and e clips. Clamp on one of the 4 mounting ears in the vise. If you did all this correctly the carrier will turn clockwise and lock up counter clockwise. If you need more help call 5153680533
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
