Re: H water pump rebuild
Posted by Kevin Meier on January 03, 2015 at 11:13:13 from (208.90.10.9):
In Reply to: H water pump rebuild posted by bassmasta76 on January 03, 2015 at 10:25:44:
the tube will press out but you don't need to unless you are machining the impeller mating surfaces. Just use a wire brush and a drill to clean.
