Re: farmall h water
Posted by old on January 03, 2015 at 18:45:49 from (209.86.226.56):
In Reply to: farmall h water posted by p schacht on January 03, 2015 at 18:26:56:
Question is has it locked up yet?? If is has not pull the plugs out spin it over till you get most of the water out then mix HEET with a quart of ATF and fill the cylinders cover the exhaust and it should be just fine till you get to it. If locked up blow it out the best you can then fill with the same mix and cross your fingers
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
