Well lets starft with checking your ING. timing and set it for full advance and full throttle , now as to the exact timing spec.'s on your tractor that one is not burnt into my computer and is in the books out in the truck . and i am NOT going out to the truck since it is cold out thar. You say you rebuilt the carb , fine but did you reall rebuild the carb . next did you check fuel flow from the tank to the carb ???? should be a full line flow . What plugs are you running ??? as for myself i will use a C86 AC - or the autolite ones , NO champions and NO HOT PLUGS . Next up the grade of gas your using they do not like cheap gas . We are starting to have problems with our gasser now because they have cut back on the octane again . Our fuel supplier told us this summer that he was no longer able to get us the 93 as now the best they are sending is now 90 and to get the 93 they would BLEND it , Well now we have two 706's down with burnt pistons and i am done trying to make them work . So either we are going to scrap them or they will get a transplant to either a Cummins or a DT 360 . Now if the housing market was booming maybe plant houses and forget about the farming and fixen old junk.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
