Re: 424 trans leak
Posted by pete 23 on January 06, 2015 at 20:35:40 from (74.33.82.245):
In Reply to: 424 trans leak posted by Heyseed on January 06, 2015 at 18:27:24:
I will qualify my answer in that I have no experience with that model but it sure looks like that front cover with the two bolts showing is what you are referring to. That looks like a dry housing which would mean the transmission input is what is leaking inside of that housing and the cover is just a dirt plate. Excuse me if I am wrong. I would just loosen plate a bit if that is the case and you will only lose what has leaked into that housing and then you can see where it is coming from.
  Upload Photo  Select Gallery Photo  Attach Serial No List
