Re: 424 trans leak
Posted by Rex in Australia on January 07, 2015 at 00:49:20 from (120.151.10.212):
In Reply to: 424 trans leak posted by Heyseed on January 06, 2015 at 18:27:24:
You got it Pete! That's the clutch housing. Meant to be dry.
Heyseed, by the look of your machine it has not got the additional speed amplifier fitted to the front of the transmission.? If you are certain that it is indeed transmission oil leaking, It should be a fairly straight forward replacement of the input shaft seal on the transmission. Yes, the tractor has to be split, but they are quite simple to work on and the seals are a standard size. I did my 434 a couple of years ago on my own.
All the best with it, they are a good little tractor.
Rx
  Upload Photo  Select Gallery Photo  Attach Serial No List
