Re: 424 trans leak
Posted by MJ in the UK on January 07, 2015 at 03:05:53 from (81.148.217.146):
In Reply to: 424 trans leak posted by Heyseed on January 06, 2015 at 18:27:24:
Hi Hayseed, remove the tin cover from below the clutch housing then look up into the housing to see were the oil is coming from. It could be coming from the gearbox input shaft or the big cast plug that seals the bottom shaft. You can run the tractor with the cover removed to see were the oil is coming from. MJ
  Upload Photo  Select Gallery Photo  Attach Serial No List
