If the smoke (assumed o be there) is much less when running under load, and gets worse idling or going down hill, it is probably valve guides. With good compression, putting seals on the stems under the retainers is cheap and simple. Even umbrella seals will make a drastic difference. Perfect Circle style seals are better. I use a 2 foot length of cotton rope pushed in through the spark plug hole (with some hanging out) then turn the engine by hand till the rope holds the valves shut. (assumes the rocker has been removed and the pushrods pulled out to allow removal of the keepers and retainers/springs. The seals are installed and the retainer/keepers put back on. The seals keep all but a small amount of oil from being sucked past the guides. If the engine smokes under load, it is going to take additional work to diagnose (possibly rebuild) and cure the problem. Synthetic diesel grade oil 15-40 can also be a partial solution. Jim
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
