Re: 1955 300 burns tons of oil
Posted by pete 23 on January 07, 2015 at 17:03:23 from (74.33.82.245):
In Reply to: 1955 300 burns tons of oil posted by PretendFarmer on January 07, 2015 at 10:18:31:
Try some of the suggested remedies and if that does not help, most likely the oil rings are just plum worn out. You can have very good compression and still burn lots of oil. Also, if the oil rings are bad, that much oil moving past will help seal compression rings for a good reading. Also, where does a piston get it's lubrication from. It is from the throw off of the connection rods. Therefore, excessive clearance on rod bearings causes more oil for rings to control. That is one thing no one ever seems to consider but it is a subject preached in rebuild school.
  Upload Photo  Select Gallery Photo  Attach Serial No List
