Re: 1955 300 burns tons of oil
Posted by PretendFarmer on January 07, 2015 at 21:36:46 from (68.0.250.212):
In Reply to: 1955 300 burns tons of oil posted by PretendFarmer on January 07, 2015 at 10:18:31:
The plugs are literally soaked in oil. All of them have oil on them but some are worse than others. It burns a bunch of oil on startup but continues to burn it after that. If you start it with the barn doors shut itll fill up with so much smoke you can't see. After it runs for about a minute the smoke goes down a little. The best way to keep it from smoking a lot is to keep the rpms up. If you let it idle too long it'll foul out a plug.
Definitely not leaking hyd oil into the engine or vice versa.
I'll be starting the atf idea in the morning.
