Re: 460 will not keep running
Posted by captian6 on January 10, 2015 at 14:24:57 from (108.209.155.151):
In Reply to: 460 will not keep running posted by rustred on January 09, 2015 at 17:39:02:
I have checked the rockers and set the gap at .027, the intake manifold gasket checked out ok, pulled the carb and for it full of crud so will now rebuild the carb and try again, it is getting good spark and the timing is correct. thank you everyone for your input and ideas.
