Re: Schebler Carb no idle adjust
Posted by hattrick on January 10, 2015 at 20:33:29 from (50.34.107.53):
In Reply to: Re: Schebler Carb no idle adjust posted by gene bender on January 10, 2015 at 20:24:52:
I am trying to adjust the idle mixture. I do not see what the idle screw would have to do with it as it is just a stop. Even if it is idling too fast if i bottom out the mixture adjustment it should change the idle or even die. I could see the butterfly having an effect though. If the mixture needle/seat and passage was plugged would it even run?
  Upload Photo  Select Gallery Photo  Attach Serial No List
