power steering piston gear alignment? IH 330
Posted by wildernessbob2063 on January 11, 2015 at 06:34:27 from (67.6.80.75):
This morning I'm putting my power steering back together on my 330 and am having some friction when I turn the wheel all the way one direction. The photo shows the piston gears when the pump is all the way compressed. does the mesh look correct?
When I turn the wheel all the way the other direction there is some friction the last 1/2 turn. It appears the plate the piston is attached to is bottoming out? When the piston is removed there is no friction.
I'm thinking the piston gears are not aligned correctly?
I took the steering assembly apart and the gears for each shaft align perfectly in the center of each other.
Any thoughts? third party image
This post was edited by wildernessbob2063 at 06:50:29 01/11/15.
  Upload Photo  Select Gallery Photo  Attach Serial No List
