Re: IH 330 restoration and cleaning clutch and tranny
Posted by Charlieu on January 11, 2015 at 09:25:24 from (206.8.2.191):
In Reply to: IH 330 restoration and cleaning clutch and tranny posted by wildernessbob2063 on January 10, 2015 at 16:57:30:
third party image
third party image
third party image
third party image
Cleaning the clutch housing is a messy job. I use mineral spirits and parts cleaner brush and then spray down with brake clean. These pictures are from a SM that I split last fall to fix the oil leaks. When I took the clutch apart it also needed to be replaced. The rivits that fasten the lining to the disc were starting to wear into the flywheel. I replace the seals on the front of the transmission and also the rear crankshaft seal. Replaceing all of these seals will help keep the clutch housing clean for a long time, I hope.
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - Maintaining Rubber Tires - by Staff. The broad use of rubber tires on farm tractors and machinery has resulted in a great saving in both time and operating costs since the time of steel wheels. There are, however, certain basic fundamentals in the care of tires that should be followed carefully if the owner is to derive maximum benefit from his or her investment. First and most important is to maintain proper pressure for the work at hand. Your best guide to proper inflation is the operator's manual or instruction book tha ... [Read Article]
