Re: Re: Re: Re: German diesels?
Posted by Red Button on January 10, 2001 at 20:17:11 from (205.188.197.168):
In Reply to: Re: Re: Re: German diesels? posted by Lee K. on January 10, 2001 at 14:15:48:
Early 706 had 282D or C263 Gas later 310D or C291 Gas The later 706 is about 3" longer because of the 310D engine same as 756
Post A Followup
: Re: Re: Re: Re: Re: German diesels?
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
