Re: cub service
Posted by John M on January 11, 2015 at 14:14:26 from (209.213.30.16):
In Reply to: Re: cub service posted by gene bender on January 11, 2015 at 09:49:09:
They are/were when this happened. The starter on the Cub had been rebuilt probably 8 weeks prior, and the starter/genny on the 154 was serviced and repaired shortly before I got it. The wires and cables on the Cub are/were new, and the cables at least on the 154 were new. It wasn't bad enough to warrant anything needing replacing or servicing, just spun over a few more times than what I call normal, probably due to the cold, or the smaller batteries used on these 2 tractors. If I plan to use them at all in the winter, I change the oil to straight 30wt and the problem seems to be non existant. These are the only ones I have this problem with. My Ms and I4 usually fire right off.
  Upload Photo  Select Gallery Photo  Attach Serial No List
