Re: Farmall H rod bearings
Posted by Janicholson on January 11, 2015 at 14:39:02 from (74.60.94.18):
In Reply to: Farmall H rod bearings posted by cool hand on January 11, 2015 at 14:17:06:
Lock washers are not used on rod caps or main caps.
Best practices today have generally dismissed lock washers in critical applications due to their ineffective holding power in hard materials and hard nuts, and their tendency to split in half causing connection failure. Locking tabs are used and do what they are supposed to do. Jim
  Upload Photo  Select Gallery Photo  Attach Serial No List
