Re: M valve stuck
Posted by old on January 11, 2015 at 15:31:34 from (209.86.226.34):
In Reply to: Re: M valve stuck posted by Eric Allen on January 11, 2015 at 15:19:40:
One way to test if it is exhaust or intake is pour ATF down the exhaust pipe with that plug out. If you start getting ATF out the plug hole well you know it is exhaust. If that does not work fill the cylinder with ATF and if you get ATF out the carb it is intake. Ya I could look and know but then I have messed with engines 40 plus years now
  Upload Photo  Select Gallery Photo  Attach Serial No List
