Re: Farmall 230 hydraulic pump
Posted by cj3b_jeep on January 12, 2015 at 13:03:37 from (131.123.222.90):
In Reply to: Re: Farmall 230 hydraulic pump posted by gene bender on January 12, 2015 at 12:48:31:
third party image
You take the cam gear off, mount the pump into an aluminum saddle, then in place of the gear there is a drive flange that goes on. Then it has a rubber coupler to the crank pulley. Finally there is a custom manifold for this application. It's the way it was set up if you had a three point hitch back in the day.
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
