Re: 350 Transmission
Posted by D Slater on January 12, 2015 at 13:55:54 from (184.14.164.167):
In Reply to: 350 Transmission posted by Dennis@mo on January 12, 2015 at 13:35:23:
Use two dowels in transmission bolt holes. Make sure to get the transmission pilot bearing started into the shaft coming out of the T/A. I like to have the belt gear box or cover off for making sure the bearing is the correct level and rollers of bearing squeezed in to start. If not enough stuff removed to do that, put a rubber band around the rollers. Won't hurt to leave the rubber band inside. Put pto in gear and turn pto shaft to line up coupling splines unless it has a PTO disconnect. Option on a 350. If so you can move it to disconnect before joining. Get housings square and straight.
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership, ... [Read Article]
Latest Ad: Variable pulley for case 1530 skid loader [More Ads]
