Posted by Dean Olson on January 12, 2015 at 17:59:37 from (107.129.21.194):
In Reply to: McCormack Disk Plow posted by grampsh1 on January 05, 2015 at 16:13:58:
It's adjustable to the wheel width on your tractor. Set your wheels all the way in, put the plow on the tractor, and then line up the plow so the front disc dumps its load behind the wheel/in the furrow. If I'm remembering correctly mine is set so the center of the front disc is lined up on the inside of the the right wheel.
There is no set measurement.
That all applies if your going to use it. You may have to adjust it if your not happy with the way it's plowing.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
