Re: 53 Farmall super M stuck or froze in 2nd, won't move.
Posted by asburytl on January 12, 2015 at 18:26:01 from (216.249.236.248):
In Reply to: 53 Farmall super M stuck or froze in 2nd, won't move. posted by farmboy48 on January 12, 2015 at 17:48:08:
Thanks for the quick responses! It was not in a heated barn but normally parked inside on level ground. I did go out and check and it will come out of 2nd gear and go into other gears, but won't go back into 2nd gear. I'm assuming since it was on a slight grade it shifted the fluid and froze something. I will try putting my nebco on it for awhile to see if it breaks anything loose.
