Re: 53 Farmall super M stuck or froze in 2nd, won't move.
Posted by lfure on January 12, 2015 at 18:55:25 from (68.169.254.14):
In Reply to: 53 Farmall super M stuck or froze in 2nd, won't move. posted by Owen Aaland on January 12, 2015 at 17:13:14:
It's going to take hours to get the ice to thaw out. I had this happen to a JD B years ago. What I did was make a shield around the bottom of the tractor with some sheets of tin. I filled a metal bucket with charcoal and lit it up, then placed it under the tractor. Be careful when you drain the water out though. You just want to back the plug out until the water starts to seep out around the threads. I've seen a lot of people back the plug all the way out and not be able to get it back in when the grease comes gushing out. It even happened to me, once. :(
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
