Re: 1952 Super A
Posted by T_Bone on January 11, 2001 at 06:42:04 from (207.254.52.137):
In Reply to: 1952 Super A posted by Boo Boo on January 10, 2001 at 10:33:50:
Hi All, I disagree with it doesn't matter which way a battery is connected exspecially in a 6v system. A postive ground will flow better than a negitive ground on a 6v battery. On a 12v battery them same is also true but is not as noticeable because of the higher exerted force over a 6v battery system. The same however does not apply to electronics. There a negitive ground flow system has a better flow than a postive flow. Almost any electronics book will explain the therory in more detail.
This is also true in DC welding machines as flow is from negitive to postive, hence the term straight polarity.
T_Bone
Post A Followup
: Re: Re: 1952 Super A
