Re: Super A wheels??
Posted by WellWorn on January 14, 2015 at 18:03:27 from (75.226.182.66):
In Reply to: Super A wheels?? posted by Willmckeel on January 12, 2015 at 10:14:59:
The wheels and tires you choose should be according to the use the tractor will see. If you are going for a restoration, use as close to a factory size tire as possible. If you normally work 'hard' ground, a narrower tire will do just fine. If you work 'soft' ground, you will want more flotation and a wider tire is better, but they will also slip more on hard ground.
Only you know what you will be doing with your tractor, so the choice is fully yours - get what fits your use.
