504 is a step up from an H for sure! Live hydraulics, IPTO, TA, factory 3 point with draft control. For my uses, an H or M would only be for antique tractor pulls. Which I am shopping around for.
I have a Farmall 504 diesel that I put a Koyker 220 loader on in 2008. I am the 3rd generation owner. It has done almost everything that I ever threw at it. Sometimes I felt it was a little gutless, but its over 50 years old and needs an inframe OH and inj pump work. I have maintained 50 acres with it for the past 8-9 years.
It will pull a 10' disc, it will run a 6' rotary cutter, it will run a 88" flail mower, it will run a 66" drum mower, it will run a Vermeer 504C round baler, and the list continues. It will out work a H and is about the same size and weight.
The only downfall is the C153 gas engine. I don't think its a sleeved engine and if it needs rebuilt, it will require machine work. This is what El Toro was in reference to. Personally I would not ever entertain the idea of a gas tractor if I was going to actually work it. Gassers have at least 2:1 fuel consumption over a diesel.
The D188 is sleeved. The D188 is a tough little diesel! Keep it at 1800-2200 and it will work as long as you can stay on it and use less than 2 gallons/hr.
I do not believe that the 504 is "more complicated" to work on. It just has more parts because it is more of a true row crop tractor. Hence TA and draft. Not saying the letter series are inferior, in any way. All I'm saying is the 04/06 series have more features that make working a tractor more efficient than the letter series. Which is true for most makes when the next generation of tractor went into production.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
