Re: 53 Farmall super M stuck or froze in 2nd, won't move.
Posted by Owen Aaland on January 15, 2015 at 01:09:00 from (216.47.34.37):
In Reply to: 53 Farmall super M stuck or froze in 2nd, won't move. posted by asburytl on January 12, 2015 at 17:13:14:
If warming the transmission makes no difference my next guess would be that something has jammed into the teeth on the constant mesh gears in the front of the transmission. Try blocking the clutch down so it is released and then engage either the belt pulley or PTO and see if you can rotate the transmission backwards. If you can I would remove the belt pulley assembly or cover from the top front of the transmission cover. That will allow you to see the gears in the front of the transmission.
