Re: I'm back with another hydraulic question.
Posted by mkirsch on January 15, 2015 at 11:20:14 from (72.45.143.81):
In Reply to: I'm back with another hydraulic question. posted by lfure on January 14, 2015 at 17:11:29:
The power beyond port is designed to withstand the high pressure generated when you actuate the fast hitch. That high pressure "backs up" through the system back to the pump.
The return port is not. It MIGHT hold up, but I've heard of people splitting valve bodies on valves that did not have power beyond. I would imagine the return port on a valve with power beyond isn't any stronger.
On a low pressure system like this it probably won't be a problem, but why take the chance for wont of a single part?
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
