Re: IH 300 Utility 12V Conversion
Posted by rhtx55 on January 15, 2015 at 17:36:57 from (68.191.209.251):
In Reply to: IH 300 Utility 12V Conversion posted by woodsmanmark on January 15, 2015 at 17:23:54:
Optima makes a 6 volt battery that will solve most of your problems. It may be cheaper than a 12 volt conversion, and it even fits inside your battery box.
Since it's dry , no more rot issues, and it can be shipped straight to your door.
Optima Batteries
8010-044
6v
Battery Type:AGM
Cranking Amps at 0 Degrees F:800 amps
Cranking Amps at 32 Degrees F:980 amps
Reserve Capacity:110 minutes
Length (in):10.000 in.
Width (in):3.562 in.
Height (in):7.812 in.
Weight:19.000 lbs.
