Re: D-358 ENGINE HEAD BOLTS
Posted by MikeJM on January 15, 2015 at 18:59:28 from (69.248.215.112):
In Reply to: D-358 ENGINE HEAD BOLTS posted by BillOHIO on January 15, 2015 at 17:37:28:
Are you sure they are 9/16 and not M14x2? They are very close.
If they are 9/16 deere and later fords use 9/16 bolts. For 14mm Arp, A1 or extreme studs might be able to help. If you can use bolts don't overlook McMaster Carr and other fastener sources.
