Re: C123 build
Posted by kub6040 on January 15, 2015 at 19:31:22 from (173.202.170.175):
In Reply to: Re: C123 build posted by Cliffton D on January 15, 2015 at 16:46:59:
How much engine do you want , I guess what I mean is
your pocket is the limit . I would use the 123 kit
use 2.02 gm valves and on a all fuel head with dome
pistons , large cam ,and a late model manifold
ported and polished , but I ain't rich , just
thinking of what could be done if you can afford it.
  Upload Photo  Select Gallery Photo  Attach Serial No List
