Re: IH 300 Utility 12V Conversion
Posted by redgems on January 15, 2015 at 21:04:34 from (204.14.163.20):
In Reply to: IH 300 Utility 12V Conversion posted by woodsmanmark on January 15, 2015 at 17:23:54:
Depends if you want it for work or show.
If show I rebuilt my generator with 12 volt every thing and went to electronic ignition with hot coil & wires. works perfect and is 12 volt but looks original.
Need to change voltage reg. and light seal beams but every thing looks the same accept for the thunder volt coil.
Tony
  Upload Photo  Select Gallery Photo  Attach Serial No List
