Re: C123 build
Posted by hendrik on January 16, 2015 at 08:30:58 from (84.35.5.78):
In Reply to: Re: C123 build posted by kub6040 on January 15, 2015 at 19:31:42:
Kub6040, why an all fuel head? A distillate head or a kerosene head has lager combustion chambers (and shorter valve stems) than the gasoline head, giving a lower compression ratio.
Thanks, Hendrik
  Upload Photo  Select Gallery Photo  Attach Serial No List
