Re: IH 300 Utility 12V Conversion
Posted by mkirsch on January 16, 2015 at 12:01:09 from (72.45.143.81):
In Reply to: IH 300 Utility 12V Conversion posted by woodsmanmark on January 15, 2015 at 17:23:54:
The electrical could not be any LESS complicated. It can be done with the existing wiring.
On a 300, or any tractor with a remotely-mounted voltage regulator:
1. Disconnect the 6V battery.
2. Swap all the wires on the ammeter.
3. Mark the "A" wire on the generator.
4. Remove the generator.
5. Install the alternator.
6. Connect the "A" wire to the alternator's BAT terminal.
7. Connect a short wire from the alternator's BAT terminal to the #2 terminal on the alternator.
8. At the voltage regulator, disconnect the wire from the GEN terminal and connect it to the BAT terminal so there are now two wires connected there.
9. Disconnect both small wires from the coil.
10. Connect the short coil wire from the distributor to the - terminal on the coil.
11. Mount a ballast resistor in a convenient location near the coil.
12. Connect the long coil wire from the ignition switch to one end of the ballast resistor. This is the "12V" end.
13. Make up a new short wire to connect the other end of the ballast resistor to the + on the coil.
14. Connect a wire from the 12V end of the ballast resistor to the "arrow end" of a large diode obtained from Radio Shack.
15. Connect the "line end" of the diode to the #1 terminal on the alternator.
DONE.
