Re: Farmall F12/F14 Replacement Rim Options
Posted by StrikeForce on January 16, 2015 at 17:23:51 from (70.15.234.215):
In Reply to: Farmall F12/F14 Replacement Rim Options posted by rhtx55 on January 16, 2015 at 15:52:39:
Just so I understand this correctly, these style rims were NEVER used for rubber from the factory? These all were cut off and welded? Thus why I am seeing so many different versions of them when I'm looking around?
