Hy-Tran has a specific gravity of 0.89 (http://www.viscosityoil.com/pdf/P13_24.PDF), so lighter than water. Solid ice is 0.92, hence it would sink. Crushed ice is 0.59, which would float. I'm guessing then that what I see going into the filter is ice from the transmission gears or what was emulsified and later froze. Which is good, it means I'm down to the last few bits.
The best way to get the water out may actually be in cold weather. So long as it's turned to ice, it can be strained. Boiling it out of the fluid should only be necessary when the water is emulsified or still liquid.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
