Re: doing a rebuild on a 504 gas engine
Posted by Janicholson on January 17, 2015 at 17:56:47 from (74.60.94.18):
In Reply to: doing a rebuild on a 504 gas engine posted by jehepe on January 17, 2015 at 17:47:22:
I believe the split is needed. The cylinders should not have more than .005 taper (wear) measured at the top of the top ring travel. If you can feel a ridge there with your fingernail it should be measured. If OK the ridge must be reamed/or machined out to assure that the top ring will have a place to break in. Check piston ring grooves for wear and clean them to metal (depth). There may be a source for oversized pistons, but they would be pricy. Best of luck. Jim
  Upload Photo  Select Gallery Photo  Attach Serial No List
