Like any other tractor for rear seal replace splitting is needed to remove clutch/flywheel... to get at the seal. If you have a lot of blocking and a pallet jack( or some type of hoist), the whole front and engine can be removed as a unit. Just block up from pallet jack to frame rails/engine and under rear end, remove bolts and anything else in the way, and slide apart. If you have a hanging hoist or loader chain assembly tight, near back of engine/frame rails and remove carefully. Block securely when off and working on it. Did this method to split on Farmall706, Cub, A and JD2440 (maybe others, just don't recall). Didn't have any problems yet.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
