Re: Help Me Make a Fair Offer on a 706G
Posted by Cory Schmidt on January 19, 2015 at 14:58:17 from (64.246.253.39):
In Reply to: Re: Help Me Make a Fair Offer on a 706G posted by Curt Cooke on January 19, 2015 at 13:55:59:
We have a 706 it sits out most of the year because the shed is full of everything else. Never had a problem with engine do to weather yet. Had other problems resulting from oil or fuel, but not weather. We use it sure, but if it still runs strong after sitting there can't be much wrong with engine. The gauges might be broken wires from a small animal getting to them, can't say for sure.Call me a nut, but the gauges aren't that important anyway, just have to manually check things more often. The 706 here the gauges don't work either, haven't for at least 10 years. Wires were disconnected after a small fire (dust that had built up got to hot) burned harness. The distributer was also replaced, that runs tach, with one that didn't have connection. I would like to find the proper dis. only so I can run the baler better; without tach have to guess RPM (baler works better just under the rated 540PTO RPM).
This post was edited by Cory Schmidt at 15:17:28 01/19/15.
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
