Re: H engine dipstick
Posted by FBH44 on January 20, 2015 at 02:24:04 from (64.85.214.235):
In Reply to: H engine dipstick posted by bobcatdan on January 19, 2015 at 17:17:26:
Yep, I did it on my 1950 "H". Realized I was never checking the petcocks. I removed the oil pan to see where I was, and figured out the angle, and then drilled 1/8" hole about an inch or so, in the boss you mention, removed and over-drilled 3/16". Then went back and drilled 1/8" another inch down, over-drilled that 3/16, etc., til I got drilled all the way through. Object beng to not break off a dril bit. Drilled 1/4", etc., til I got all the way through, about 2 1/2" of cast iron. Threaded in a pipe nipple, probably 3/8" dia., and used I believe it was a Ford dipstick. Works great. Misses the crankshaft by about 3/4".
  Upload Photo  Select Gallery Photo  Attach Serial No List
