Re: super MTA diesel
Posted by D Slater on January 20, 2015 at 16:53:12 from (184.14.164.167):
In Reply to: super MTA diesel posted by boberjagel on January 20, 2015 at 15:31:50:
Open the water trap vent and the rear filter vent with tank valve open. When fuel comes out without air close and start tractor on gas. Vent front filter when clear close vent and if more venting is needed at the injectors, open throttle some while running on gas. Hytran or 10 weight engine oil in PTO. Probably better use hytran or equal in PTO because if the PTO input seal leaks any transmission oil and PTO oil will mix.
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
