Backfiring is a sign of timing miss. Which can be caused by a sticky/bad valve, bad valve seat, bad gasket seal, bad plug/wire, out of time, whisker (carbon/dirt in plug electrodes), spur on the points and a hot spot in the cylinder among others.
A good way to check for a bad gasket, vacuum leak, is to spray WD-40 around the manifold and carb and see if the idle RPM changes.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
