Re: New Temp Gauge not working??
Posted by jal-SD on January 21, 2015 at 18:01:06 from (208.53.222.164):
In Reply to: New Temp Gauge not working?? posted by Whoa Nellie on January 21, 2015 at 17:56:02:
Cover the radiator with something to let only a
little air through, take off the radiator cap and
run it until you can see the water circulating past
the neck of the radiator. Get your wife's candy
thermometer, and stick it into the radiator to get
a temperature reading & compare it to the gauge
reading. (My $0.02 worth. jal-SD)
  Upload Photo  Select Gallery Photo  Attach Serial No List
