Re: '51 Super C not getting spark
Posted by Brownie450 on January 22, 2015 at 04:27:29 from (66.43.241.198):
In Reply to: '51 Super C not getting spark posted by 06 DIESEL on January 22, 2015 at 04:01:14:
Do you have a voltmeter? Pull the switch out & check for voltage at the coil or if there is a voltage dropping resistor, check for voltage on both sides of that.
If voltage is good, take off distributor cap & dust cover. Take coil wire out of dist. cap & hold 1/4 inch from a good ground. Making sure points are closed, open & close points by hand. You should have a blue spark at coil wire.
If no voltage at resistor or coil primary terminal, check switch & wiring to switch.
  Upload Photo  Select Gallery Photo  Attach Serial No List
