This could also be due to excess resistance in the coil circuit.
I bought an 8N Ford that acted the same way. It had a 12 volt alternator conversion kit.
Whoever did the conversion used a direct 12 volt coil (no resistor required) but did install the resistor and the resistor measured 5.5 ohms rather than the 1.5 to 2 ohms that it should be.
I removed the resistor and it started and runs like it should.
Check to be sure you have either a 6 volt coil(1.5 ohms across small posts) and a near 1.5 ohm resistor, OR a direct 12 volt coil (3 ohms across small terminals) and no added resistor.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
