Re: '51 Super C not getting spark
Posted by old on January 22, 2015 at 08:41:26 from (209.86.226.32):
In Reply to: '51 Super C not getting spark posted by 06 DIESEL on January 22, 2015 at 04:01:14:
First off check for spark at the coil wire that goes to the center nipple of the distributor cap. Should be a blue/white and jump a 1/4 inch gap or more. If no spark hot wire it. Go from the ignition side of the battery to the ignition side of the coil and check for spark. If you have spark then you know the problem is from the coil back to the battery. If no spark then the problem is in the distributor
  Upload Photo  Select Gallery Photo  Attach Serial No List
